Asko dryer problem (fixed)
cfz2882
Feb 9, 2010
2,724
Belle Fourche,SD
My 24" Asko condenser dryer,-did not find model #,but i think it is a tc712-got a habit of shutting off before load dried:thought the motor was overheating or there was a lint blockage,so rocked dryer back and began inspection:took plastic cover off front of recirculation blower,thinking a thermostat was under there and discovered 2 plastic plugs had came out of the air duct to the condenser core compartment,causing a big leak of hot air directed under the drum.The plugs were ~7/8"and snapped securely back in,so i do not know why they came out...dryer performance back to normal-if these plugs pop out again,will secure with a daub of silicone RTV...This is a great little European dryer,clean the condenser about every 6 loads :)
