ASKO W660 Washer Drum Clicking
spacedogb
Nov 15, 2014
250
Houston, TX
Hello everyone,
I added a set of ASKOs to my collection. I am currently using them as my daily units. I have only had them for 3 days but I am noticing a clicking sound when the drum turns. Can someone give me some insight into this sound. I am not sure if it is normal or if something is wrong. I am linking a video from someone else who's drum is making the same sound. Thanks in advance for any help you can give.
http://https//youtu.be/nEBjJOtRaP8
Foreign Object
Sounds like a foreign object has found its way to the outer tub. Rubbing against the hole pattern in the inner basket. I would remove one of the paddles and have a good look all around the tub. Could be a bra wire maybe.
Malcolm
The noise has returned. It seems it only happens when I fill the unit to the max with towels and run the 205 degree cycle. Its not a water boiling sound but that clicking sound that I hear when I turn the drum. Could it still be a foreign object even though the clicking is intermittent?
