Hi All,
I recently bought an Australian sold Kitchenaid KDS-17, manufactured in former West Germany. I have connected it up to use in my kitchen and I put it through its first run today. All seemed to work except for the following. Hope someone can help !
1. Small water leak from the lower left corner of the door. The door seal looks OK. The service manual also mentions a baffle which it says needs to be sealed in the corners. Not sure if it could be this baffle or the seal.
2. Another very small water leak around where the forced air duct locates in the bottom of the tank.
3. The forced air heating element cycles on and off (presumably the overheat switch going open circuit). Also there doesn't seem to be much air coming out of the front lower edge of the door, so wondering if the overheat problem is due to insufficient air flow.
Pics attached. Thanks ever so much !
