stricklybojack
Ad copy:
Western Holly 50's Oven.... relive the past in style. Gas Oven by Western Holly
Call Mike& Debbie for appointment to check out by calling show contact info
Condition: Used, an item that has been used previously. The oven is made by Western Holly.
This oven is in pretty good shape for its age and condition. The enameling is in really fine shape, with just one spot on the lower left side of the lower door showing some metal. The interior granite paint has the usual wear but much less than one would expect for an oven of this age. The sides, which you wouldn't see are painted a flat black and look good. There is a chrome trim frame and "Western Holly" Chrome 18" nameplate grill. The stove does have all of it's racks.
At the top is the oven temperature gauge, a gas knob for turning on the oven, and on the right a combination timer and clock. The thermometer looks good, This stove plugs into a 115 v outlet and hooks up to a gas line. The ovens are 17" wide. The opening needed in a cabinet for this wall oven is 21.5" wide x 44" high. As an older oven I would suggest you have a professional take a look at it.
Check out www.western-holly.com or www.antiqueappliances.com/products/restored/1947_westernholly.htm
Also, for a reprinted Western Holly Oven Manuel you can contact: Antique Gas StovesP.O. Box 9507 Alta Loma CA 91701( show contact info
This oven has some weight to it, probably close to 75 lbs. so I can offer a few different shipping options. Of course local pickup is one. I can provide delivery at $1 a mile, or the buyer can set up their own shipping using u-ship or some other arrangement. I can get this secured to a pallet for that kind of transport.
Call Mike& Debbie for appointment to check out.
Ad copy:
