Balancing Siphon Coffee Maker
michaelman2
Apr 25, 2005
1,512
Lauderdale by the Sea, FL
I was at a dinner Saturday and my friend had one of these for the after dinner coffee. It is beautiful and really fun to watch. The coffee it produced is of course great as siphon machines typically produce great brew. The little alcohol burner made it completely portable and the way it works is really cool, fully mechanical and balanced.
I think the article that I found below is really better than anything I could write...(this is my preface of "footnoting") :
Regardless of how delightful the finished product may be, most methods of brewing coffee are pretty dull. Drip machines just sit there and dribble, percolators burble a little, and plunger pots don't do anything at all. If you enjoy having people over for coffee, you might want to try a coffee maker that puts on a show.
The balancing siphon coffee maker is an elaborate device for making coffee, and it's both beautiful to look at and fun to use.
The set-up consists of two canisters, or jars. One is usually metal (for the heating of the water) and the other is glass (for the actual brewing). There is a small alcohol burner that sits under the metal canister, and the two canisters are joined together by a slim pipe. Here's how the system works:
You place the ground coffee in the glass jar, and boiling water into the metal chamber. Light the alcohol burner to continue heating the water. As the water boils, it flows through the pipe and into the jar with the coffee grounds. The water is just below boiling when it mixes with the ground, which is just ideal for excellent coffee. Eventually, the water chamber will boil empty, and the balanced lever will tip the canister and put out the burner. Meanwhile the coffee is happily brewing in the glass jar. When the metal canister cools, it creates a vacuum, and the finished coffee is sucked back through the pipe from the glass jar. There is a spigot at the bottom of the metal chamber, where you pour the finished coffee.
There are no filters to alter the flavor of the coffee, and the nature of the system keeps the water at the right temperature for brewing. Though it will make you a great cup of coffee, this might be too elaborate for your important first-thing-in-the-morning cup.
I had seen this at the Grove Park Inn years ago.....I have to have one now.
Sweet Baby Cheeses...
Please don't get me going on another coffee maker. I just don't have room for another one.
Malcolm
Hahahaha...Hey Malcolm,
<strong>
<p>I was thinking the same thing.  But when I saw this little jewel in action I was hooked.  This is just a cool machine. The one below is identical to the one my friend has and used at his gathering.  To see this in action was really very "alchemist -tical".
I am with you, I do NOT need another gadget, but I am kind of making my way over to Ebay every so often for this little devil.
</strong></p>
Let Me Know...
when you take delivery of this little beauty and I'll come by for a cup of coffee... :)
Malcolm
Jack Nicholson's character
in "The Bucket List" had one of these coffee brewers, and brewed Kopi Luwak, the world's most expensive coffee in it.
I think I'll stick with my Melitta one cup cone or my Krups auto-drip. And a very good dark roast decaf a friend sent recently.
Lawrence/Maytagbear
Yup, I noticed they had The Bucket List as a movie that this type of coffee maker has appeared in when I searched for it.
I think the ingenuity is what intrigues me about this. Granted the cup of coffee is the same as any vacuum pot, very good.
While it looks and sounds like an interesting coffee brewer, I'll stick with either my percolators or the vintage Norelco Dial-A-Brew.  I prefer simplicity whenever making coffee.  It would be fun to see one in action however.  If seen first hand, I might be convinced otherwise.
Wow Mike that is a beautiful coffee service.  How long did it take to make the coffee?
Hey Terry,
It took about 3 mins for the entire procedure.  Terry, it was just so cool ...once he lit the burner the kettle heated the water to the boiling point ...it forced the boiking water into the glass vessel that contained the coffee and Bailey's...then when the kettle lifted as it got lighter due to the water being boiled out the small burner was extinguished due to the hinge on it being triggered.  Then the kettle cooled a bit and the coffee was syphoned back into the kettle and was ready to pour.....The second picture is a very eloborate set up.
They have them in a much less fancy model.
Very Cool
I'm a coffee junkie so this would be a cool addition to my collection. I will have to keep an eye out for one. The only downside will be explaining it to my partner as to where 1 more coffee pot is going to go.
Hey David, I found several on Ebay.  That set up with all of the fancy china and tray is quite expensive. It can also be found on a site "Royal Coffee Makers"...Google that and it will come up with the correct address.
I found just the coffee maker itself without the fancy schmancy cups and so forth, on Ebay and it was not expensive second hand.
Jimmy, I know how ya feel..I have too many "things" as it is. Recently when I was assisting my parents move from their home to an assisted living condo, I realized that my parents had too much "stuff".......of course once we liquidated a good deal of their home and moved them into the condo, they decide three months later that they are moving BACK INTO THEIR HOME ....oy!
Mike, found it. You are right, very pricey, even for the palladium model. I'll look for a used one, sans service set. I have nice china and crystal that I can use for the service set.
Hey David,
Yes, that is what I had planned on doing as well. Really your idea is a good one about using your pieces (cups, saucers etc)....Those that are shown are demitasse size....not my "cup of tea"..heh
Correct, it is definitely a vacuum return, as I stated above. I too did not want the chore of keeping the brass boiler tarnish free either...So,..I got a stainless steel set. [this post was last edited: 4/8/2011-09:18]
Hey Michael, hope that you will post a picture of yours when you get it.  It really is a very interesting coffeemaker.
Terry
