beautiful g.e. dishwasher (model sd200a4)
rollermatic
Oct 10, 2009
2,068
columbus and milford ohio
well here it is straight from columbus ohio! the vintage 1966 g.e. dishwasher that was advertised on craigs list last week that i saw here.
she's a beauty! and does indeed look "hardly used".
I hope you will mix up some epoxy and coat those scratches where the silverware basket passes over the door. It's a shame they did not put the piece of plastic there sooner. You are lucky it is not more scratched and rusted.
I hope you have fun with your new toy.
now for the scary part
this one section of bottom tub makes me cringe! i know that these pastic coated tubs will rust out readily if water gets thru a break in the plastic coating! we had a g.e. and it started to rust really bad! the plastisol (or whatever it is called) kept peeling and peeling!
i'm afraid to put water in this one till i make sure this problem area is fixed and sealed!
doesn't look too
good in close up!
gonna get it inside tomorrow, hope to work on it this week. no water will touch it's tub till i am sure it is sealed!
gonna paint outside of tub bottom also with my rustoleum rusty metal primer.
love these old g.e. pumps
amazing such a little pump can move so much water thru that huge spray arm!
always did love those big huge water jets! as a kid i used to go to the stores and just stare at em! i was weird!
drain pump made out
of metal, prob aluminum.
one of my other g.e. mobile maids has a pllastic lower drain pump. larry in parma said it was a replacement pump and the originals were metal.
