Hi Charlie,
Congrats on picking up this machine, I wish you success with the restoration.
I've got a couple of these and with all of them the wiring where it enters the motor has been an issue, the bulk of the machine seems to have an early form of PVC wiring and is in perfect condition, but the Supply cord and the leads that go into the motor are rubber and generally badly perished. Make sure you inspect carefully before you try and plug it in.
On a seperate note, these are a great toy, but I wouldnt reccomend it as your only daily. I have my jumbo Malleys H Axis machine and it does ok, but you do need to go back to old style washing techniques to get good results from these machines. You will need to use the pre-wash every time and pretreat stains, plus with the one directional tumble, stuff can hang on the outside of the tub and not tumble. Essentially these machines are for getting rid of the non visible dirt and oils, anything visible needs to be taken care of before you wash. I use it for Towels and Sheets, anything that isnt generally stained, but I still spin the towels out in a seperate spin dryer before I try and hang. I leave the clothes and heavily soiled items to somthing after the mid 60's.
The low spin speed will also be an issue, you will get detergent buildup and residue on most things, I'd suggest alternating loads between the bendix and something more modern to make sure you get the detergent out.
I dont want to put you off, I'm just trying to make sure your aware of the compromises that go with this.
Cheers
Nathan
