archiving, analog vs. digital, tuners
Well, yup, sorry, didn't think. I am not going to miss analog tuners, either.
When we went to digital terrestrial here in Germany, lots of salesmen pulled the same crap on customers. You will have to buy a new TV, new VCR, new new new...
Nonsense.
The digital tuners in the beginning were very expensive. Today they are sold in the grocery stores, many for under 30€. So I wouldn't let myself be driven into buying anything until the system is up and running.
The picture and sound quality are quite good, by the way.
Kevin, I archive in five steps.
1) Transfer using "lossless" compression Codecs (HuffYUV, PCM 16bit 44.1). (anal retentives, let's not and say we didn't, ok? This is going to be a simple discussion and not a knock-down "mine is bigger" fight.)
2) Perform all cropping, editing, cleaning-up, etc. on this material with a maximum of editing done each time (that is, cropping, sound compression, color correction, etc. all in one pass).
3) When I am satisfied that the material is ready to archive, I compress it with xvid and LAME (xvid High Definition, two pass, LAME 192k, 44.1, Stereo...unless it's Dolby in which case I AC3 the tracks separately).
4) One copy is kept on two separate HDs, one burnt to an archival quality DVD (also supposedly 100 years) and one burnt to a cheap DVD to be played on standard MPEG4 compatible home theatre players.
5) I cross my fingers. I have zero faith in the long term stability of DVDs and strongly suspect the HDs, which are swapped out regularly (they'll run reliably for the length of their guarantee of 3, resp. 5 years in every case) will prove the more reliable choice. I never replace the hard disks together and always use two different manufacturers.
Kevin - I kept this very simple, cause the anal retentives drive me ape-shit with their nit-picking (HuffYUV does lose gamma color-space when incorrectly predicting left-shift and RGB24 modus is not blah, blah, blah...) but if you have any specific questions - feel free to write me. I'm not brilliant, but my profession demands a fair knowledge of the technology...
