Hi, all!
Just one question, really:
In your experience, what are the best detergents, of any format, for rinsing? By that, I mean which has the least (or no!) foam/suds and clearest water left at the end of the rinse cycle (excluding the fabric conditioner’s slight foaminess)? Also, I know some of you use slightly less detergent than recommended because you find that a little less still does a good job without causing any problems, as well as believing detergent manufacturers get us to use too much anyway. Any thoughts on this from anyone?
I know this can all depend on local water conditions, the amount of detergent used, programme used (agitation in particular)… We have *very* hard water, but it’s been turned soft by a water softener that is regularly checked.
To give you an example of how much foam we get, just one UK Ariel tablet will foam up in the machine terribly, even though Ariel foams up less than it used to. Ariel powder, however, is not too bad actually on with normal dose… but I want it to be better!
hehe
Answers from all over the world of course!
I know this may be due to water-saving and energy-saving measures, which I support, but I do remember my 1980s Hotpoint Microtronic L.E. and my grandmother’s Zanussis from the 1980s and 1990s rinsing to clear water. However, this may have also been due to the detergents used then, which was Persil non-bio powder in all cases and with the same local water supply, as well as the fact that there machines did about five rinses each as a matter of routine! LOL
I know foam is fun, but it’s a pet hate of mine when it comes to rinsing my daily loads.
I use the correct amount of detergent, and we get pretty good results with Persil non-bio tablets, Ariel Sensitive liquitabs or Tesco Naturally non-bio tablets. All of those produce little foam during the wash, as well as quickly rinsing out to produce clear(ish) rinse water with only a slight head of foam. However, I want to see if there is something better! ;-) I’ve tried one Persil tablet, which I know some here do, too, and that works well.
I have eczema and want to try to get as little foam in the later rinses as possible, although I know that skin sensitivity is not all about how much foam is left.
And this may be a daft question, but what exactly leaves all that foam behind? Is it water softeners? Polymers? Foaming agents? I haven’t a clue!
I know this may have been covered before, but I do miss high water levels – I have Water plus turned on on my Miele with the extra Water plus options programmes as followed (all turned on):
1. Wash water level increased.
2. Rinse water levels increased.
3. Extra rinse added automatically. (My Miele does two rinses as standard on most programmes, but mine will do three because Water plus is turned on.)
Any ideas?
My machine rinses properly, so there are no faults or issues, and the modern Bosch and Hotpoint we had before produced much the same amount of foam anyway. I just want less foam, even though it’s not too bad anyway, but I just don’t like foam in my penultimate rinse! Grrr! ;-)
Thanks very much.
Regards,
Carl
Any ideas?
Thanks very much.
Regards,
Carl
