Betty is Back with another Full Cycle Video the '49 ABC-O-Matic
Thanks Robert, for that highly amusing video.
Amazing how you managed to create those voices... Betty, Gladys, etc.
Did you use some sort of A.I. to accomplish that?
Yes I sure did use AI for the voice narration, and it seems to have advanced quite a bit in quality since I did my last video about 4 months ago.
Yesterday, I watched the 1935 film Magnificent Obsession, a treacly, over wrought film and BETTY FURNESS plays the doctor's daughter. I never knew she starred in anything except Westinghouse commercials and that fraudulent cookbook that was really written by Julia Keine. Anyway the Westinghouse commercials are more substantive than her role in this pot boiler.
Does the washer drain the outer cabinet during agitation? I ask because at starting at 34:50 the machine appears to oveflow about 12 (?) gallons of water and then at 37:05 starts gyrating. IIRC I remember members a while back telling me these machines pumped out water in both motor directions but unsure if that holds true with this machine.
It popped up on my YouTube last night and was wonderful. Excellent work, Robert. I wonder if that 2.5 minute neutral overflow is a bit wasteful, maybe they should have just done 2 agitated rinses instead? Amazing turnover of a full load, and excellent film-making! One of the cooler machines around, thanks for the washer history lesson. Did ABC have a drier at the time?
Yes the pump runs in either direction so as long as the motor is running it is pumping out water. It's about 6 gallons used during the overflow. The water valve has a flow washer regulated to only fill 2.4 gallons a minute.
Actually the machine uses just under 30 gallons per load total even with the neutral overflow, just about 1 gallon more than a Unimatic (28.5 gallons) so compared to other machines of the same time it's not really using any more water. In 1950 a GE AW6 uses 34 gallons, the Whirlpool used 36 gallons, the AMC used 46 gallons and the Maytag AMP used 29 gallons as well.
Robert, just have to say you are so creative, that video was great and so informative. Just love the other guests in the film as they made it a bit more special with their comments. Great job.
Doug
