Not that easy
Disassembly of the door is a little complicated. I was able to take apart the hinges well enough to remove the door and feed out some of the cut wires to splice them. Now, unfortunately, it looks like either the timer advance motor, the sensor pad or the circuit board that governs the electronic sensor is not working. The dryer went for two hours on its maiden voyage--set on "NORMAL SANITIZE" far past dry.
At least I know the dryer works, heats up etc. And then right after I started him up, there was one last wad of lint on the other side of the blower blocking air flow. The blower may be standard size, but when it's not clogged with lint it works pretty well. Big design flaw of this unit is the inability to remove the lint filter to be able to vacuum out the lint well.
But I'll say one thing for Big Boy, when he's put together and level he's extremely quiet.
He's doing another load right now, set on NORMAL. We'll see how this one goes. By my clock, he should be done in 15 minutes.
