that will remove 26 AMPS from the timer block in my Charcoal '57 Frigidaire at spin up! The timer contact was rebuilt in the 1960's and"Mother-Superior" tells me that they used brass rivets which came loose, sure enough my contact is looser than a gooser and at spin up gets so hot you can't even touch the outer control tower.
So I have put in a HONKIN huge power relay to take all the juice to the motor.
If you look around the world of electronics you will see there aren't many devices in the world that ever use 26 AMPS at one time! This is one of them.
