Bounce dryer sheets
henene4
Feb 6, 2013
4,486
Heidenheim a.d. Brenz (Germany)
I used to use dryer sheets back home and when I didn't own a heat pump dryer.
Actually, I started the whole dryer sheet thing in my family as a kid.
There was a coupon for a rebate in a leaflet we got back then and convinced my mum to try them.
And we just kept buying them.
We always bought the blue Lenor once and they work amazingly in a condenser dryer.
But with heat pump dryers, since they don't get that hot, that thin fibrous kind with a waxy coating in them don't usually work that well since the temp dosen't get high enough to transfer the smell enough.
There is a different kind of dryer sheet over here that are packaged like wet wipes and feel like them. They work great in any dryer but I never found any I liked the smell of.
Recently I impulse bought some US import Bounce dryer sheets.
I got them off of Amazon and calculated down to the sheet, they aren't much more expensive than brand name once from a store (it's like a cent more).
And I must say I love the smell.
It's not really comparable to anything - no softner, you can't even give the smell a "color" like most softners do (blue, yellow, pink etc.).
The best way to describe it is "dryer smell".
Laundry from a regular condenser dryer has that typical dryer smell - it's the same type of smell like the "freshly ironed" smell, but somewhat different - more present, but less intense.
But from a heat pump dryer you get pretty much no smell at all if the laundry didn't have any treatment on it.
This emulates that smell.
However I won't be ordering them again.
As nice as they smell, they produce an obscene amount of dust. The fluff is hard to remove - it sticks to it self, forms these very tiny balls and those are basically impossible to remove from the filter without getting them on the floor.
I deeply dislike dryer sheets.
I had a very brief fling with them when they first came out, but my washer had a perfectly good dispenser for liquid softener, soooo
Where I really hate them with the heat of a million Suns is at the Coin-op.  ALL the dryers are gunked up with dryer sheet residue.  Disgusting.  When I could, I would just take my damp wash home...
Lawrence/Maytagbear
I prefer liquid on the occasions that I use softener.
I haven't used dryer sheets in many years but I bought a package, local/regional grocery house-brand, last year.  My dryer dries faster than most such that a noticeable amount of the "product" remains on the sheet for lack of time and duration of heat exposure to distribute into the clothes.
Bounce was definitely a feature of suburban Dublin in the late 80s and 90s. In the area I grew up in, washing a machines and dryers often lived in the garage or in an external laundry room. I have a very clear memory of Bounce (on a roll, not individual sheets) wafting out of dryer vents.
Condenser dryers didn’t feature much here until the 2000s and really until heat pumps became rapidly established, a lot of people seemed to see condensers as a last resort / a lot of hassle. So a majority of dryers were just straight through the wall vents.
There was some use of gas dryer too, more so in rural areas a LPG suppliers often used to (and still do) pitch SpeedQueen dryers to their customers.
Bounce got replaced by Lenor branded sheets and seems to be just becoming more and more niche. It’s definitely not compatible with heat pump dryers and I would be a little concerned about gunking up their far more complex condenser systems. You can’t just whip them out and run a hot shower through them.
The other weird product I remember here was Dryel. You had a big zipped bag, which you put your woollens or delicates into and added liquid impregnated pad, like an extremely wet dryer sheet. Then zipped it up and put it into a timed cycle in the dryer. I remember it being in the house and being used about twice and generally being a bit of a gimmick. It certainly didn’t do what it claimed to. I think that was also a P&G product.
If you’re in Germany, try ordering Soupline from French Amazon. It should deliver at no, or very little cost. Might just be another dryer sheet brand to try.
https://www.amazon.fr/Soupline-lingettes-assouplissantes-grand-air/dp/B01DHWB5E2
Soupline : https://www.soupline.fr/produits
They’re made in France by Colgate-Palmolive (France)
1980s Bounce UK / IE avert - featuring Creda Dryers
Here’s how Bounce was marketed in the mid-80s around here.
Maximum hairspray too!
And featuring a Hoover stack:
HP condenser issues
Have to say that both heat pump dryers my mum had now never were any better or worse than others I have encountered.
And with my Miele, it's been more than a year of somewhat heavy use and not a trace of anything. That filter system really is above average.
I've a Miele heat pump that's been in use since mid 2017 and it gets LOTS of use and is still not showing any sign at all of fluff build up.
I did replace the foam filter though as soon as I saw any deterioration at all. Quite careful to ensure that the condenser system stays protected.
I wouldn't add dryer sheets though just due to their waxy nature and the cooler drying temps might not be ideal.
The perfect dryer for Bounce sheets
Is a good old fashioned gas vented dryer they work well in there.
As others have stated HP is too cool and I too do not like the waxy feeling goo to be stuck on a self cleaning condenser !
Austin
Something like this ?
To be quite honest, I find the need to use dryer sheets went away with enamelled drums. I remember our old Hoover “Tumble Dryer Deluxe” which probably dated from about 1978. Those machines were based loosely on a European standard sized cabinet version of Maytag ‘Halo of Heat’ machines. Lint filter at the back of an enamelled drum, and the air was drawn by a large through heaters that encircled the door.
When we swapped it for a Miele vented dryer, probably in about 1995 the static cling issue disappeared entirely. I’ve had Miele machines myself since too and none of them have ever produced any static. I assume the stainless steel drum is properly grounded.
In general I wouldn’t really see much need for Bounce anymore. The sheets were always handy as drawer / cupboard and even suitcase fresheners though [this post was last edited: 1/26/2022-19:04]
@iej
Yes book fresheners is what they get used for mostly these days !!
Oh and tuck one behind a radiator it makes a lovely room fresh scent.
Austin
mrboilwash
Amen! The Unstoppables were not my favorite, but were OK. I have said this about having an Outdoor Fresh Downy and potentially Tide for years. But I would rather them leave the Bounce version alone. Lol.
There's actually a version of the unstoppables in the Ariel scent, so I suppose there's no reason why they couldn't do a Bounce version.
https://shop.supervalu.ie/shopping/...iel-in-wash-scent-booster-264-g-/p-1760552003
Ariel has a quite hard to describe scent, but it's uniquely 'Ariel'. It's not floral, nor is it fruity.  Historically it's kinda piney-citrusy, but neither of those things .... hard to explain lol
They reformulated it in the early 2000s and it was so pungent it gave me a headache but it's a bit more subtle these days. I still don't use it tho lol I prefer my laundry to smell a bit less overpowering.
I'm guessing Unstoppables aren't selling well here as they're almost permanently on sale these days.
Two of the biggest sellers here are Unilever's Persil Non-Bio and Comfort Pure, and I would suspect a lot of that is driven by scent.  Both of them remind me a lot of Dove soap bar type scent - extremely mild and light by laundry detergent standards.
I tend to use Miele Ultraphase and Comfort Pure as softener. Like the scent of both of those. Miele Ultraphase had a scent problem initially which has been ironed out and it smells lovely now. The first version smelled great, but then would fade to this bitter scent that was quite unpleasant. Now it's just a nice, very 'clean laundry' scent which I find rather pleasant compared to anything else on the market here.
When the W1 is on a very hot wash it smells great - scent of the Ultraphase 1 detergent wafts around. It's a fairly subtle, but very 'fresh laundry' kind of scent.
I made sure to have a spare and I switch them out when one needs cleaning. This also alleviates the issue of putting the plinth filter back in even ever so slightly damp and causing a fault in the machine.
Chuck
(No on dryer sheets here.)
