bmr6969
So picked up a kds60a and the thing has two weird things going on no matter weather or not the handle is down the thing will run. I',m assuming it has something to do with program switch and secondly the timer is not resetting at end of cycle again is that switch related?? Can I use any timer from the kds20 series or does the A change that???? Help help help!!! By the way the kds18 you helped me with is running flawlessly!! Anyone else chime in as we'll too! Thanks guys.
