Can a Microwave run continously?
Chetlaham
Mar 11, 2013
4,231
United States
As an Amazon Associate we earn from qualifying purchases.
Thank you. I love your experienced replies on appliance matters! :)
Its good to know I can use my countertop to cook full family size meals. My current Sharp R21LCFS doesn't have a power level function but I know that might not even be a setback. It is good to know I can set the knob to a full 6 minutes 3 or 4 times in a row without significantly shortening the life of the oven.
I'm actually debating on purchasing a second microwave oven but one with a keypad so that I can cook for longer than 6 minutes while having the option of multi stage cooking. I can cook lasagna, casseroles, pies, ect in the touch pad in an hour while heating rolls, gravy, sacuses, ect in the knob version side by side.
Well back in the day, 70s & early 80s , microwave cookbooks touted cooking whole meals and roasts in them which could run around 45 minutes.
One small appliance you can't run for long though are KA and Kenwood planetary mixers. They're good for about 10 minutes maybe even less with a heavy load before requiring a cool down period.
GE Thermo Probe Models
Before I forger, I remember in the 90s GE offered over the range models with a temp probe that plugged into the side of the cavity. The idea behind it was I'm guessing like that in the video. You cook the chicken until it hits temp in the thickest part then you let the cooking process finish. Rather ingenious now that I think about it- but I admit that I've never seen or heard of anyone taking advantage of the temp probe feature or if it is even offered new.
When we moved to Calgary in 86 I bought the full size GE (Baycrest rebadge) which had auto everything including the probe. It was by far the best mw I've ever had. It had no turntable yet cooked everything evenly. It was always the top scorer in CR's ratings as well. It had a metal shelf, auto roast with the probe, auto defrost, auto cook. You just put your food in covered, hit the appropriate auto button and that was it, no need to add the weight or amount. I'm a bit forgetful but I'm sure we had it when we moved here in 2006 but it eventually died. Could be wrong about that. After which I used my old Amana Radarange for a while till it had some issues and went down into the basement where it sits today.
Actually I`ve got countless of appliances that are not supposed to run continuously from vintage to brand new.
Picture #1
my 50`s kitchen motor has "KB 10 min" on the rating plate which means "Kurz Betrieb 10 min" or "Short term operation" in English.
#2 is a cheap modern file shredder wich calls for a 30 min cooldown after a 1 min use.
#3 is my new Oster blender that should not run for longer than 2 minutes.
Could go on and on with this quiz but I think I made my point already.
As for microwaves I think to recall the older ones with mechanical timers went up to 45 minutes maybe even longer, so I`d assume that continuous operation should not be a problem.
Except for maybe the food catching fire after a while.
Reply to John's quiz
Lots of small kitchen appliances aren't rated for continuous operation.
I have seen mainly food processors, stick mixers and blenders with short on cycles - the worst I've seen was a cheap stick mixer with 30 seconds on / 5 minutes off cycle. (Max usage time 30 seconds, then must rest for 5 minutes before being used another 30 seconds max!)
Slightly off topic... It's not exactly a duty cycle, but just last week I got rid of a good quality Panasonic bread maker (gave it to an opp shop) because after baking a loaf, you can't do ANYTHING until it has cooled to below 40 degrees C. If you try, it flashes a "hot" message till it has cooled. Not even a bake only function - which means if your bread comes out a bit undercooked, you can't just put the loaf back for another 15 minutes baking. I bake gluten free bread which often needs a bit longer than the standard cycle. I have replaced it with a Breville which has a better shaped loaf pan and does allow an extra bake-only cycle immediately after a loaf has completed a cycle, so I can give it an extra 15 min or so if needed.
(Though I am finding gluten free bread is much better baked in a proper bread pan in an oven, than in a bread machine. Even special GF cycles don't rise long enough or bake long enough.)
The "hot" message is probably to prevent the yeast from dieing if you try to cook 2 loafs after each other.
That feature being active on the just bake setting seems like a programming oversight.
On the topic of microwaves duty cycle: If I can set my microwave to 90min, I don't see why the duty cycle would be less.
I know that for example the EU BSH Oven/Microwave combos step the power down from "Max" which is either 800 or 900 watts to 600W of the course of 90s.
But it can sustain that continuously.
With any bake mode selected that is limited to 360W, but also continuously.
Most of these duty cycle things are for small appliances where additional cooling would mean weight or size increase (or sometimes even cost).
Since you wouldn't use many of these things long anyway, it usually isn't an issue.
But some manufacturers take it a bit to far - can't purée a soup in 30sec, can you...
@mrboilwash: Lucky. My current microwave only goes up to 6 minutes which got me double questioning if the oven has the ability to withstand 45 minutes of cooking. 2-3 minutes is typically enough for reheating, but cooking meals is asking for way longer times. I'm itching to try a plate of raw drum sticks or a whole chicken.
That 10 minute protector in pic # is really neat. Does it switch both the live and neutral since Schuko plugs are not polarized?
Chetlaham
It`s not a protector switch, it`s just a rating plate which indicates voltage, watts and continuous run time. The hole in the center just seems to hold a rubber part in place to lower vibration or noise from the motor.
That makes sense. I guess its to deter someone from accidentally setting a burrito to 30 minutes?
Given that this unit could see microwaving may times in a row and being a commercial model construction wise I'm guessing this can handle 45 minutes of cooking better than a conventional domestic microwave.
It has been 20 years since I've entertained the idea of advanced cooking in a microwave, but after experiencing the performance of this one I am seriously getting a lot of ideas LOL.
What appliance cannot run continuously this is a quiz...
Fun idea, here's my stab at it:
Although this isn't probably the answer, I believe most modern ovens have some sort of safety feature built in that will shut off the oven by default after a predetermined period of time, such as 12 hours. As I understand, there is usually a function to override this safety feature by putting the oven in Sabbath mode when necessary.
I don't think a refrigerator or freezer compressor can run continuously either (by design). It would make it way too cold. However, not sure if this counts as the fridge itself is technically still "on" even when the thermostat is cut out. On second thought I suppose the same would hold true for an oven from a technical sense so I'm stumped :)[this post was last edited: 1/21/2024-14:26]
In my kitchen in Pennsylvania we had a GE Profile Convection Microwave. The longest I ever ran it was 90 minutes straight, BUT. I used the Combination setting to cook the best meat loaves ever. It had three different setting. I used setting 3 which was the heating temp was 350 degrees and the microwave was set for 75% power. But i don't think you could count this as continuous as the heating element is cycling off/on as in a regular oven and the same for the magnetron since it was using 75% power, but the convection fan was on constantly. Am I correct in my thinking?
