Can someone identify this washer?
this is a lower-end model of the POD 1954 or 1955 GE.  The POD model had timer dial on one side and water temperature dial on the other with the water saver switch (horizontally oriented) in between the two knobs.  Friends at the end of our street, they had the matched set--only got to see from afar.  They also had the lower-end Waste King DW compared to our higher-end 3-button WK.  Our GE washer, which replaced the Bendix because I couldn't leave it alone, looks just like Jetcone's, but didn't have filter-flo.  I remember our owner's manual had an insert for the washer I'm thinking of.  One of the two dials was referred to as Fabri-Flex.
Luigi, attached is Jetcone's 1956 Filter-Flo.  This is the washer that replaced the Bendix to keep me from opening the door and all the water going down the driveway.  Ours looked exactly like this, but our model did not have the filter-flo.  On the front of Jon's washer there's an identifying turquoise-backed script insignia declaring Filter-Flo.  Our washer had the word Automatic in it.
Our neighbours had a white one so I guess I guess their washer was perhaps from before 1955. The pictures of the cadet blue one I must have found online.
I know of several households that had a GE washer and sometimes even a GE dryer. Our neighbours weren't well to do (they didn't even have a car for a long time) but I guess they found it important to have an automatic washer with so many children, important enough to buy an import machine.
This WASHER IS NOT FROM BEFORE 1955
It is from 1955 or 1956. GE introduced color appliances in January 1955 in Cadet Blue (the color of the machine in the picture), Petal Pink, Turquoise Green, and Woodtone Brown. Cadet blue was so unpopular that it was discontinued after the 1956 model year.....PAT COFFEY
The Center-dial GE
Thank you for that picture. I am pretty sure that this is a 1953 model, WA-450K (although because of that chrome strip in the front and the slightly different RH control, it might be some non-catalog later model). I have never seen a GE washer in Cadet Blue; I've seen parts sheets that list cabinet pieces in that color so I assumed they existed somewhere, but now it's documented.
Thank you Ken for adding to my memories about that machine. They had a huge flow through water heater to have it filled. As a child I was fascinated by this machine because it was much bigger and totally different than the washing machines I knew. Short before we moved in 1975 it was replaced with a European washing machine, also a toploader, a Ruton (Philips) Slimstar.
Oops!
Sorry Louis.
