Chambers electric stove DE-100
dgdr
Mar 22, 2015
2
I was referred here because of a problem I have with a Chambers electric range. The rear burner cannot be regulated. It's always on high. Does the switch need replacement? Normally it would click off and on. Perhaps there's a thermal probe that needs cleaning. If it's a switch where can I get one? Not much info out there about the electric Chambers models.
KitchenAid bought Chambers cooking line so that they could offer builtin cook tops and ovens. Then KA was bought by WP. If you take the model number to an appliance parts dealer, they will be able to supply you with a switch that will work with your range. If the control dial is not marked in degrees and there is no sensor in the middle of the element, you don't have to worry about a temperature probe being part of the problem.
Do you have a builtin cook top and oven or one of the relatively rare one piece cabinet ranges with the oven under the surface units? Chambers made quality equipment.
