It's getting to be that time of year again! This year, I'm gonna be putting even more lights up around the house! What type of lights do you have and where do you decorate them?
I've got 5 strings that take the candalabra, or nite-lite 120 volt bulbs. I think these are called C7. They were what I remember having on the tree as a kid growing up in the seventies and eighties. The neat thing about these strings is that they are parallel wired. I've got twinkle-brite bulbs in them, and what makes them so interesting is that each bulb blinks INDIVIUALLY With all 5 strings going on the tree at the same time, the tree becomes very animated with all sorts of flashing colors and stuff...quite a neat effect!
On the outside of the house, I put some icecicle lights around the front porch of the house. I also have some 3-candle candalabras that I put in the windows with orange bulbs in them. I also put some multi-colored lights in some of the bushes and stuff, and an artificial christmas tree on the front porch. As far as non-lit exterior decorations go, I put wreaths on the front windows, and some green garland around the porch railings.
One of the neat things I think that's coming of age this year are LED christmas lights. At the end of last year, I bought several strings of christmas lights from Target. Oddly enough, I guess people didn't want the white and blue only strings. These are typically the most expensive LED's made. I was able to buy six strings of 60 lights each for $5 each. This year however, I have seen LED light strings sold for around $8 with the same amount of LED's in them. Last year, the non-sale price was about $15. Now, the odd thing I've noticed about the LED lights is that the price is the same no matter what color the strings are, or if they are multi-colored. The interesting thing is that it's actually cheaper to buy a string of 60 blue or white LED christmas lights at a discount store than it is to buy bare LED's out of an electronics supply catalogue!
The look of LED christmas lights is absloutely amazing. The colors are so vivid! The problem I have with the old incandescant miniature bulbs is that the heat eventually "burns" the colored paint off the bulbs, and reds become pink, while blues become a sort of aqua, and overall the colors become dull after using them just 1 season either indoors or out. LED christmas light strings also seem to be significantly more efficient! My Watts up meter tested the 50 light incandescent strings at about 24 watts, while a 60 light LED string came in at only 4.3 watts!
LED's also have some definite advantages when using dimmers or animating your christmas lights. The biggest advantage is that they don't change their color when they are dimmed. The second is that their life is not shortened through on/off power cycles like that which occur when using animation controllers and stuff. The life of LED's is actually extended when it's switched on and off frequently!
Now, still with that being said, the life of LED's is still not gonna take you to the advertised 100,000 hours on the box. This is because of the nature of the beast. LED's, unlike diodes in power supplies (which are designed to) do not like being "reversed biased". A diode, be it an LED or a power diode is a one-way electrical valve, and because you connect up a LED christmas light string to AC current, half of their operational life is spend being reversed biased! The manufacturers of christmas lights obviously don't put any sort of sophisticated power supply on their lights, just a current-limiting resistor.
What I want to do is make a sort of power conditioner for them. This would have a half-wave rectifier, and a filter capacitor in them to absorb surges. A full-wave rectifier would create about 170 volts DC, where a half-wave makes about 85 or so (120 volt AC house current is the RMS rating...the peak voltage is at the aforementioned 170). This would both reduce the voltage and eliminate reverse-biasing the light strings. While I may only get a few years out of the LED light strings before the wiring falls apart, at the end of the light string's life, I want to be able to recover the LED's and use them for other uses.
For now, the only thing I gotta decide on is what to decorate with my new light strings
My "grand illumination" is usually on the Sunday after Thanksgiving!
