Jackson this time, interesting variation on a theme of glass oven door. It not cheap but with all the bits its not too bad overall.
Note the grill/broiler pan which fitted under the rectangular hotplate, and the deflector that you could use to send the heat upwards if you were not using the broiler [this post was last edited: 3/11/2017-04:59]
Mid 1970s no fan oven. The Hob is obviously later than the oven and hood. The light is from British Home Stores 1978, I had two of these lights myself back then
This is the double oven version of the one just previously listed. Fundamentally it is the same as the first oven in black, but the overall size is smaller, closer on to 100cm rather than the 120cm of the black oven. The hob is 10-15 years later
