Cleaning a coffee mill
veg-o-matic
Sep 15, 2004
2,626
Baltimore, Hon!
I've been using a lovely vintage Kitchenaid coffee mill to grind my morning beans. I don't know the model number, but it looks like this picture that I borrowed from ebay.
Anyone know how to clean the beast? I'm guessing that one would want to get inside occasionally and clean out all the oils and stuff. I don't have the owner's manual so I'm at a loss. Don't want to start taking it apart unless I'm sure I'll know how to get it back together again.
veg
Bob,
My BRAUN says to grind frozen beans at the coarsest setting every few weeks, then use a stiff brush to remove any residue from the grinding surfaces and chute.
But, really, the nature of these machine is such that they are pretty self-cleaning.
One DON'T....
DO NOT grind preflavoured beans with a burr mill like this!
Grind preflavoured beans with a "windmill"/blade chopper, not a mill like this. Or a blender.
The preflavoured beans will heat, the coating will melt, and you will gum up the mill irretreivably.
Lawrence/Maytagbear
I have several burr grinders. A Braun, and Krups, and a Melitta. Currently I use the Melitta because it tends to spew fewer grounds around. But they all will clog up their discharge chutes after a few grinding sessions. And they all come with little chute cleaning tools to remedy that problem.
The coolest burr grinder I saw recently was at Costco. It's one of the heavy cast metal Kitchenaid line. Something like $100 or more, but perhaps worth it. The achille's heel is that it has a thin walled glass container to catch the grind - looks very breakable, and not something that could easily be replaces with something more durable (it's an odd inverted cone shaped thing that has to fit just so into a spring loaded seal at the top). But along with the new cast metal KA toaster, it's otherwise built to last a long time. Or so it would seem. Certainly it would make an effective door stop!
Speaking of coffee grinders/mills...
Don't do as my brother's girlfriend did... she ground some spices (cloves, or something similar), in a manually operated wooden grinder. It seemed like a good idea at the time!
Coffee didn't taste the same, for weeks afterwards...
