sudsmaster
Well I'm always a sucker for a sale, and Costco has a $20 off coupon for the Cuisnart "Convection Toaster Oven" this month.
Although I've been mostly satisfied with the electronic Oster convection toaster oven I got a year or two ago, I've never found it to be acceptable to actually make toast. I'd read that the Cuisinart was better at that. So, even though it's a model that has been out for quite a while, and might be updated sooner than later, I got the Cuisinart, and have been testing it out.
Intitial impression: the toast function is good. Not perfect, as the underside of the bread (multigrain, two big slices) that I tried was more toasted than the top. But then I also went for a light toast setting and then had to amp it up for a second try, which might have affected the result. I have to wait a day or so for my toast ration to return ;-) to test it again.
Next up was a Digourno 12" frozen pizza, supreme. This came out better than I expected - more even browning than either the Oster or my GE P*7 wall oven have been able to do. Plus this oven seems to heat up much faster than the Oster, as well as having a nifty little beeper that sounds when the set temp is reached.
Downsides: no interior light, apparently it doesn't shut off the oven when the timer setting is reached, and the crumb tray removes from the rear, which isn't a problem for me now but could be in a tighter installation space. But I'm willing to settle for these downsides if it does bread right and makes a decent pizza.
Overall quality seems a step up from the Oster, which is not unexpected.
It's probably a keeper, and for $80 probably a good value (the Cuisinart web site lists it for $180).
It looks similar to this, except the top and sides are black enamel rather than brushed chrome.
I like that it's a bit smaller, overall, than the Oster, but still fits a 12" pizza just fine.
