It would be different
Semi-Auto machines were very common over here for years.
The big difference was lack of timer, Filling mechanism, and suds diverter valve. Is it a mechanical spring type of timer rather than an electric one?
The whirlpools here, have a 3 position switch, with wash, drain, spin, each of which activates a solenoid on the wig wag. The mechanical timer controls the lenth of the wash/rinse times.
The reversing motor types usually had three buttons, wash, off spin, and the idea was that you had to go through off to change directions.
I've got a Simpson Fluid drive I'm parting out at the moment, it did away with the wash/spin solenoids and had a mechanical linkage that operated the cam bars instead.
Other than the gearbox and pump, I dont think you'll find much is compatible with an automatic. It probably wont have a suds diverter valve, as that would've occured manually, and the motor will be only single speed. The different fabric types it lists are to provide an indication of wash time, rather than a special cycle.
These machines were common overhere but rare as hens teeth in the US.
Wouldnt that Dryer match Roberts 1948 Fridgidaire?
