customline
Time to put your thinking caps on. My '55 Kenmore portable DW is doing something strange. I plug it into a regular non-GFI outlet and it runs fine. Now, this model has a nifty little dashboard light. When I put a new light bulb in and run the dishwasher,it immediately trips my cicuit breaker and the light bulb goes POOF. This only happens when the light bulb is IN. When I run it without the light bulb, the dishwasher works fine. I have a new AC cord on it, rebuilt timer (thanx to Reeco timer of Palm Bay FLA.)and I'm 99.9 percent sure all of the wiring is properly in place. Anything that was remotely leaking, I fixed. I have a single copper ground wire running from the timer to the heat coil and ends at the impeller motor. Should it run to the frame also? This inquiring mind wants to know. All of your help will most certainly be welcome and the pictures are coming soon! I promise.
