Damsel in Dish-tress [ KDS-21 ]
pamk
Dec 19, 2017
2
Lenox
Oh happy day. Oh woah is me.
I had my Kitchenaid KDS-21 installed on Friday. But, it wouldn't start. The plumber replaced the original hard-wire with a cord. Could that be the issue?
Any super expert near me who might be able to help me troubleshoot? I live in Western Massachusetts.
I write a midcentury homes on my blog, more info in my story today.
Many thanks, automaticwasherites!
http://https//retrorenovation.com/2018/02/05/kds-21-kitchenaid-vintage-dishwasher/
Welcome.
Glad you're enjoying the site. It sounds like there could be a power issue between the cord or the outlet.
It could be the micro switch on the top right of the door. When you gently close it do you here a click ? And also, is there a little rubber pointy thing on the top right where the activation (safety) switch is ?
Where did you get the machine from ?
There are quite a few experts here that will be chiming in shortly.
I hope you get this sorted out soon. Last of the Good KitchenAids.
I would think the electrician would have turned the circuit breaker off, or removed the fuse if older service, when he performed his work. Did you check to see he turned the breaker back on or reinstalled fuse?
@toploader re: a little rubber pointy thing on the top right
@toploader aka lifesaver (I hope),
Indeed, a little rubber pointy thing had BROKEN OFF from somewhere when my plumber friend got going.
We didn't know what it was. But howdy hudee, I kept it, and I actually found it easily. I see where you say it goes. What do I do now? Glue it back on? What kind of glue should I use?
Thank you!!!!
I'm glad it's an easy fix
You'll need a new one, ultimately - but for now, some glue will get you going. If a bit of super glue doesn't do it, try the 1 minute epoxy they have at Walmart or The Home Depot.
An expert will, no doubt, be along in a minute to tell you the exact part number and where to get it cheapest. Whirlpool (who now own KitchenAid) lists it as: Whirlpool OEM Part #4172040.
These were the last of the really good KitchenAid dishwashers, you will love it.
Ah-HA !!!
That would be the reason why it won't start. As panthera said...
I'll bet the ranch it should fire right up once you glue it on.
Attached are pics of my KDS 20.
1st pic is the Rubber activator. (I think the rubber is better as they don't snap off that easily.
2nd pic is the door. That little silver circle (at the top right of the door) is the switch that the "pin" pushes to start the machine. This is the safety if you open the door while the machine is on will stop the action.
You could latch the door (open) select let's say Normal wash, then gently push a screwdriver in and the machine should activate.
Looks like a happy day!
I think some JB Weld would be worth using to glue this piece back together.  That stuff dries and hardens like metal.
And yes, you did your homework and got a good machine.
Ralph
Has a good point - JBWeld could even be used to cast an entire new piece.
I always try to fix these things in a particular order - super glue, 1 minute epoxy for the simple reason that they can be removed very easily if they fail or the part is replaced. Given the clean break in your pictures, you might want to go for a much more solid connection like JBWeld.
Welcome Pam!
from a regular reader and occasional commenter, who loves what you do!
SteveT in FL is our resident Hobart/KA expert, and there's little he can't solve when it comes to our wonderful d/washers. We have a KD 17 Series ('71 to 76 ish) in storage for our retirement house. Enjoy your "Hurricane in a Box" and welcome!
RAnderson
Roger
another strategy for the long term...
which is important in a vintage machine of any kind (some even do it with cars!), is to find a parts machine, they're out there and usually very cheap or free. Many important parts such as motors are shared by all models within the same Series (20) but some, like timers, are unique. We had 3 different models in storage at one time, down to just one now, plus a box of spare parts!
Update
Hi @toploader and other new BFFs:
YES: I found the white rubber pointed pin thingy and super glued it. The glue held. Meanwhile, I bought a spare on ebay -- thanks, @panthera!
YES: It turned on! Dancing the kitchen time! I just finished reading the use booklet. For once in my whole life, I read the darned book.
YES: I'm running it. I'm running the normal cycle. So far it's made it through load water and heat water and right now it's running the first wash. Fingers crossed!
I am making a video to put on the blog. Wish me luck.
I also have a few more technical questions, which I will come back with.
Oh and that's a great tip @firedome -- I'll start looking for a parts machine right away. DH will be thrilled *not* to have that in the garage with all my other *projects*
THANK YOU, ALL, SO MUCH !!!!
Yay!
Keep asking those questions - lots of experts here. I'm not a KA expert - ours is 62 years old and worked right from the get-go.
(That was not a complaint).
Soooooooooooo glad it's running.
Just imagine how many machines were tossed to the curb if/when that part got broken or fell off.
I actually have a small cache of parts for the 18-20 machines. If you need anything please never hesitate to ask me or anyone here.
Yay !!! another Hobart saved.
I am in need of part #AP2920658 (door switch actuator kit) for my Kitchen Aid Superba Monterey 21 dishwasher and cannot find it anywhere --- can someone help me? The little plastic pointy thing broke off in the door and when i tried to fish it out it dropped down into the front panel!
Thanks All! I found one on ebay -- I was using the AP2920658 number instead of the actual part number of #4172040 when searching and it arrives on Jan 21! I was able to find the broken off piece inside the panel where it dropped inside and glued it on with gorilla glue -- it's drying now and my hope is that it holds until the new part gets here. I tried the trick with the screwdriver - thanks toploader55 -- and it worked so this was indeed the problem! I am thrilled to have saved this dishwasher and saved a great deal of money and hassle -- you guys rock!!!
