DE806 end of cycle / bell ringer assembly
hoys
Jun 23, 2017
0
Dayton
Hello all, I have a DE806 Series 01 in Harvest Wheat. I'm the original owner of the machine and would like to keep it running!
The small plastic arm that both rings the bell to notify end of cycle and pull the lever to turn the machine off has broken and I cannot find a replacement part. My machine failed somewhat catastrophically when the part broke and the small metal lever fell onto a terminal on the control panel and shorted that pin to chassis ground.
I might be able to design and 3d print a replacement, or find a machine with a compatible part.
Has anyone ran across this issue before? I don't believe I'll be able to run this machine without some other implementation to end the cycle.
Thank you!
