Dealing with Uk Miele And Replacement Machine W1 WKF120
northernmary
Apr 23, 2007
261
Huddersfield - West Yorkshire
On many occasions I’ve had miele out due to the excessive play and movement in the drum since about six months in to owning the machine. I’ve been fobbed off by the same engineer saying it was the type of bearings fitted to the machine due to it being a 7kg machine and he went away as time went on same visits about play in the drum and it had developed a creek/crack noise when you checked for movement where the lifters on the drum was once again nothing to worry about to continue using the machine, a few months after the machine stopped heating and the same engineer visited and diagnosed the heater relay had failed on the PCB and required a new board which he had on the van he programmed the board and installed it and he went away. A few cycles in to having the machine repaired and the machine would just get severely out of balance and just go for it, once again the same engineer came out and accessed the pcb via the Pc update port and he said I’ve found out what the issue is the board isn’t configured for the imbalance sensor that it has on the tub its only programmed to use the taco on the motor, he programmed the board correctly and I mentioned I’ve got a squealing noise when it first ramps up to spin puts a load in on rinse and spin and the noise was evident he said the belt is slipping and I’ve got one on the van I’ll put you one on until a few months later the issue came back and required another belt to be fitted. By this time I had really had enough I was on the phone one morning to book another service visit 12th may 2014 for rumbling on spin at this point I couldn’t use the machine above 1200rpm and the belt had started slipping again I just lost it on the phone and I wanted to put a complaint in and I wanted it to be addressed the gentleman on the phone booked the service call and then put me through to management support spoke to a lady called Hannah she asked me what my concerns and reasons behind wanting to put a complaint in so I asked where do you want me to start I said she said from the beginning so told her what I’d gone through and what parts had been fitted to a machine which isn’t a year and a half old, she said to me it sounds like the bearings have gone which are very rare as the machine is still young . She would address the issues I’ve raised and she would arrange the senior engineer to visit to rectify the situation once and for all service visit was booked for 27th may 2014 between 8am and 10am and herself would be back in touch to ensure the issues are resolved and to feed back what the senior engineer diagnosed the machine with. The 27th may arrived and the engineer arrived at 9am walked in, checked for drum movement and the creek/crack noise was presented at the same time as he checked. He said the bad news is you need a whole new tub assembly and bearings, I asked him if this is why I’ve been having replacement belts fitted and he replied yes the issue should have been addressed months ago to find out why a new machine was going through belts , I refused the repair and the senior engineer contacted management support spoke to Hannah and explained the machine needed a new tub assembly and bearings and the machine had only carried out 915hours and the machine was practically brand new, he went on to express I wouldn’t be accepting the repair on the machine as it’s a major repair on a new machine and based on previous issues and repairs carried out. Hannah said she would need to speak to her college to authorise the machine to be replaced. The same day around 2.30pm Hannah called back and said the machine would be uplifted and replaced but the 5740 had been discontinued and she offered me the 5780 I had a look online and the machine was similar specs but without the time remaining function which I use quite a bit, contacted them and expressed the replacement machine should be like for like Debbie contacted customer experience team to advice of a machine with similar specs and she would phone me back, Debbie phoned back and said she had spoken to the customer experience team and as a good will gesture due to the inconvenience caused they would like to offer the model WKF120 chrome edition which was from there new W1 Range, Powerwash system, 8kg , 1600rpm, Capdosing, A+++ and could she book in for delivery. Delivery was booked for 5th June 2014. I’ve been putting the machine through the mill since it’s delivery its smooth, silent , I’ve noticed a lot less creasing after the final spin, to say I’ve only gone up 1kg but its cut down on the amount of laundry I am doing, the drum is cavernous it’s a lot bigger than it looks. The jet cycles on and off throughout the wash along with distribution and it also uses the jet in the final rinse. Build quality wise it’s very well built and feels like it will stand the test of time. The machine will redistribute a few times if the load is imbalanced so the spins are smoother with less vibration and noise produced. I haven’t used the capdosing yet but I don’t think I would to be honest I like to change my detergent frequently and I like to control dosage to load and soil type. The machine has handled everything I’ve thrown at it and it’s taken care of it and produced excellent results.
I’m pleased with the outcome of the situation I’ve had and it’s shown there are company’s out there that look after their customers and ensure there happy with the end result. Miele have gone above and beyond to ensure the issue has been resolved and that I am happy, one thing I did forget to mention that they have given me a 10 year warranty on the WKF120 as the 5740 had a 10 year warranty. I’m one HAPPY customer !!!!!!
I’ve started to put some videos on my youtube account the link is below
Had a quick view...
... and 2 things have been improved on the cycle it self and one in the new line:
1. No more fuzzing around on interim spins. I remeber our Mieles to darin, distribute at least twice and than spin. Took a bit long for my taste. This one drains, distributes and spins in less than a minute.
2. Rinse waterlevels are just perfect. Not more, not less...
3. The spins are quieter than half a year ago. One person on YT returned his because of loud rattling noises during spin.
Thumbs Up...
What a beauty!!! I'm pleased Miele have given the excellent service you deserved after all that fiasco. Just goes to show the loyalty they have for their customers. Thanks for giving us an insight to the workings of this machine. Thumbs up buddie x
Henene4 thelaundrylab
henene4
The machine uses water wisely and doesn’t skimp on water neither I haven’t had to use water plus once on the machine as of yet, I’m impressed with the rinse results and I haven’t had to adjust the water programming in the settings menu.
The distribution between rinses has improved; less fuss just gets on with the job in hand and moves on to the next stage in the cycle. The programming seems to of been refined and the run up to the final spin aids less creasing of the load.
The machine is a lot quieter is an understatement it’s down to the Profi eco motor which I understand is brushless, there is really no comparison between the WKF120 and the 5740 when it comes from noise when the machines was in use.
thelaundrylab
Thank you Hass, They have looked after me I know some people aren’t keen on the brand but they have lived up to their reputation and have gone above and beyond to keep the customer happy
Hi Northern Mary,
I've had a similar experience with a W3933 6.5kg model, but it was 4 years old. Miele attempted a bearing replacement at no cost and when that failed after 6 weeks, they gave me the option of 50% of original value, or a complete drum assembly replacement. For a 4yo machine, I thought the offer of a 50% buyback was very generous.
I took the Complete assembly replacement and 9 months later the machine is the best its ever been.
If at first you don't get a good outcome from the main contact center, contact a Customer Care advocate and they really work hard on your behalf for a good outcome.
The new machine looks beautiful.
Regards
Nathan
It does warm the heart to hear such a good story from one of the world's best washing machine manufacturers. We have a W5740 and she is still going very strong! Hope we will have a lot more years of service out of the machine.
Hope this one treats you very good!!.
Cheers
From what I've read, the drum runs a little slower (probably during the rinses), the jet runs less and there are two rinses with a brief spin burst before each one. Cycle time is 65 minutes.
Reply's :)
brisnat81
I’m glad they rectified the issues with you as well, it’s nice to hear your machine is back to normal and the various options they offered you showed good company ethics and ensuring your happy at the end of it , thank you the machine is beautiful and am sure yours is too!!!
mieleforever
I’m sure your 5740 will serve you for many years yet, my 5740 was just a Friday machine I’m convinced too many issues in a short space of time. I’m pretty optimistic the W1 will treat me well so far I’ve put it through its paces and it’s handled everything I’ve thrown at it …
logixx & mielerod69
I’ve used the quickpowerwash tonight and the cycle time was 59 min’s and it just did one rinse but the rhythm of the wash and rinse cycle was interesting, don’t think I’ll be using it very often to be honest. If I was in a rush and wanted to get a load of laundry processed quick id select cottons 40 with short which takes it down to 59 min’s with two rinses, I wasn’t keen on the one rinse I don’t see how it can be effective.
German forum link
Hi Logixx,
could you post the link to the German forum. I think I lost it with some of my internet upgrades.
