Definitely about time
adam-aussie-vac
Dec 14, 2017
1,092
Canberra ACT
Hey everyone, I thought about replacing the cable on my vintage Ukrainian Soviet heater, it dates back to 1985, and after noticing the plug was slightly melted I decided to open it up and have a look and I think it’s definitely time to replace it, Should I replace it with a two wire cable or should I attach a ground to the outer casing, even though the inner casing has been physically insulated with ceramic insulators?
Oh, F me, who fitted that plug???
that plug has been fitted wrong and is quite dangerous.
The wires should be tucked around the little lugs that form a cable restraint - to stop the wires pulling out if the cord is yanked.
You can see a tiny slot in the base halfway between the pins in photo 1, there will be a protruding plastic lug above each slot and the wires should be threaded around the lug.
How many amps does it draw? Standard Australian plugs are only good for 10 amps, European appliances often draw 13 or 15 amps, this is enough to burn out an Australian plug if there is any imperfection in the connection.
The more I look at that wiring, the more I think you should cut off the cord and keep the heater as a curiosity, not a working heater. It is so far from a safe design it is ridiculous. The insulation is rudimentary, the cord anchorage is terrible and non-compliant, and it should be earthed.
If you ignore my advice and repair the heater, at the very least get a moulded in one plug and cord, and use one made for high temperature devices. Standard flex would melt inside that heater. High temp cords have a different feel, more rubbery than plasticky. (But they aren't rubber, to be clear.) The cable often has "High Temperature" or a numerical temperature rating printed along its length.
But please don't. That device is inherently unsafe.
If you burn the house down, you would probably be uninsured as that heater doesn't comply with Australian codes, even those from decades ago. And you or someone else might end up dead.
So it uses 1 kW at 220 V
I’m just wanting to bring it up to Modern Australian standards and I have done a little bit of research, the only difference between a class one and class Zero appliance is the presence of an earth conductor and lead, In no way am I trying to ignore your advice, but it’s not the first time in my immediate family we’ve had to make an old heater Into a display object(As my mum’s vintage heater she got from her grandfather had asbestos insulation for the wiring), which is honestly something I don’t want to do with this heater, I’ll probably go with 1.5 mm² HO7 Cable which is that rubber silicone high temperature stuff, I’ll probably go and ask a couple of different electrical appliance places here as well as asking my mum‘s electrician for advice as well Before going ahead with absolutely anything
Great news, I got the heater redone and out of all places
At the motor shop, I’ll send some photos of the cord with plug, by the way the plug shown actually come from the same country as the heater And it’s physically compatible with Australian plugs and sockets, so I’m very much happy with that Plus unlike my mum‘s heater there wasn’t a trace of asbestos or anything close to that, so once it was all together it’s really really good
