Desperate need for wire diagram
ssteen25
Sep 12, 2011
7
Hello I have a maytag dryer model# 641c I need a copy of a electrical wire diagram or service manual, It turns on cycles and turns off when door switch is open I have ohm'd the heater element and all t-stats still have no heat when I removed the back cover to inspect and clean out I found yellow and thick green wire laying in bottom of drum Im assuming these have something to do with it but all my exsperience is in newer appliances I havnt seen anything like these since I was a child. Any help would be greatly appreciated thanks
I believe these dryers were refered to as halo of heat models seen pics on other threads, I can just about make anything work if its not the exact model just need something that shows where the wires all are supposed to go to.
9 pages from Maytag Halo of Heat repair manual(p79)
The inside of the front cover, unscanable, says:
New Model # DE-DG700 equals old model #641C-741C
Also, page 79 posetd here, 1st paragraph, : The information in this supplemental may also be applied to the Models 641C and 741C."
I am not an expert at old Maytag dryers, I am just posting from a service manual.
9 pages follow
(carefully follow page numbers, my posts may not be in order.
[this post was last edited: 9/17/2011-23:12]
