DG108 into DG808!
I meant to take pics, but got carried away installing it...here are the modifications needed in addition to swapping out the consoles
1. Drill 2 timer mounting holes at the 12 and 6 position....the existing ones were at the 9 and 3 positions
2. Replace the DG108 dial with a sungold dial
I was going to hook up the wires for the light to the start switch...that seems to indicate the light will be on while the motor is running...probably need a new bulb..it's made by Westinghouse..and a new ballast...stay tuned!
