cfz2882
Had a post on these devices a while back:meant for warming truck cabs,boat cabins.etc.these heaters run on 12 or 24v dc and burn diesel fuel in an enclosed,forced draft combustion chamber.Been using a couple of these to heat a 12v backyard building: very pleased with the performance so far using a Russian made Autoterm 4D- 4KW of heating power and very reliable though i had to partly dissasemble and clean a screen around the "glow pin"ignitor when screen became fouled when i tried a mix of diesel and used motor oil
The fan motor,BLDC on the Autoterm,runs about 3000-4500 RPM. Combustion air and burner exhaust are piped from outside the vehicle or building,so very safe.Have also used a 2D Autoterm and a couple Chinese made Vevor ones.The chinese heaters are real cheap:~ $125
