gnfnrs_gnr
Hi All,
I have a 80's Dishlex dishwasher (Glendale Deluxe) based on the Smeg design. Last week it wouldn't fill with water. It would only let in a very small amount (3-4 litres). So I replaced the water inlet valve with a known working replacement from a previously parted out machine. This didn't fix the issue. I tested all modes and the only mode the inlet would open briefly was the ' rapid wash' cycle.
I prodded the pressure switch and its vacuum hose with my hands and then the machine started filling. I then replaced the pressure switch with another second hand part (thinking the pressure switch was on it's way out) and the machine functioned perfectly fine for about 8 cycles across the last four days. Dishes came out piping hot and spotless. This included putting a cleaning cycle through it with the Finish dishwasher cleaner solution.
Tonight, the machine is exhibiting the same problem as previous. Letting in a small amount of water and not filling. It's going about its full cycle with barely any water. So with no float mechanism, inlet valve working, pressure switch working, good pressure from water supply and inlet hose all fine, would could be the problem?
Thanks
Thanks
