Hello:
I'm concerned about mold growth in the dryer, so, I'd like to leave the door open.
Unfortunately, there is no off switch for the light, and I don't want to have to remember to go back there after a couple of hours to close the door.
So, I was wondering: Is it safe to put the washer and dryer on an outlet controlled by a switch?
1.) Amps used by the washer ... It washes at 8.05-8.10 ... spins water out at 8.91 ... fills at 7.95 ... spins water out at 7.90 to 7.61
2.) Amps used by the dryer ... It starts at 8.00 and cycles down to 5.80 to 5.85
The highest of both would be 8.00 + 8.91 = 16.91 . . . and my circuit breaker box is 15 amps . . . Nothing has ever happened when I run both at the same time
My washer and dryer are both currently on a 15V GFI . . . I'm thinking that I will the washer and dryer on a 20 amp switch, on this GFI.
I know that with a space heater, though, you don't want to go through a switch (or extension cord), because that interferes with the circuit breaker's ability to detect dangerous surges from the device, and flip:
Observed amps in my Lasko Digital Ceramic Heater - Model CC13652
. . . in Standby . . . 00.08 - 00.11
. . . on High . . . it initially goes up to 15.00 . . . then settles down to 11.50 - 11.75
. . . on Low . . . it goes to 6.25 - 6.35
. . . so, that's why I'm not sure if putting the washer and dryer on *a switch* is a good idea, or not.
A friend said that she always just closes the dryer door, and has never noticed any problems with mold.
So, I'm wondering - does enough air get into the dryer with a closed door (are they designed this way?), so that it's ok to do that?
On the other hand, you do want to leave the door open on the washing machine, to prevent mold growth - but there's no issue there, because there is no light.
Thank you for your time and assistance.
