draining pump
rene
Jul 12, 2015
4
Toronto, Canada
Would anyone have any suggestions for the following: I have a couple of wringer washers and I am planning to be away for 6 months and, I concern about the draining pump seizing during my time I am away so is there anything/product that I could use to put in the pump?
thank you in advance for any suggestions.
As long as the drain hose is lower than the bottom of the tub, like on the floor, there will be no water left in the pump of a wringer washer. Thats why you can gravity drain thru a pump and an automatic washer with a siphon break and an outlet for the drain on the top of the back you will need to get RV antifreeze in the pump to prevent freezing.
Six months is not a very long period of time.
My Maytag wringer was sitting idle far longer than that and pump was fine when started. It now has developed a leak, but that is another matter.
Long as you've drained water out of them, don't think your pumps will be harmed during your absence.
What normally happens with wringer and other washer pumps that sit idle for very long periods is the crud, scum, detergent residue (powders), and so forth turn into a hard mass. This can prevent impeller from spinning. If your machines are working fine now, and have been well maintained, don't think it will be an issue.
IIRC the only other real worry about leaving washing machines and dishwashers idle for prolonged periods comes from being exposed to very cold to freezing temps.
