Several years ago when Fred G. (Blackstone) was closing out his family business, I had the opportunity to buy a couple of MIB electric skillets, one Universal and one Toastmaster, both stainless steel. Last night for my latke frying, I pulled the Universal by Landers, Frery & Clark out of the box, cleaned it up from almost 50 years of just sitting there and used it. I was leary of how it would work because it is very light weight. I read that it is a stainless, copper, stainless sandwich construction, very expensive to make. The heating element was unusual in that it was very thin, followed the perimeter of the pan and then made a loop into the middle. Fred did let me have an additional Universal heat control with the pan so I felt I would have a backup if the first one did not work.
I mixed up some really good latkes with zucchini, carrots and celery added to the usual ingredients and went to start frying. First of all the pan heats almost instantly, but you really can't use the recommended heat settings because they used the same for both their stainless steel and their aluminum skillets and as anyone who has cooked in stainless steel knows, you have to use lower heat in frying operations. GE stressed that in their surface unit instructions, saying to use one setting lower than for aluminum pans and 25 degrees lower for the Sensi-Temp unit. So, when I could see that the oil was hot enough, I turned the heat control down to where the light went out and it was at 250F. I had sprayed the pan with Pam before adding the oil. I fried the first batch of 4 and I have never had such perfectly even results in an electric skillet. All evening long, as I stood there and fried and ate, the results were unwavering. Since the heat setting was definitely suspect, I unpacked the second heat control and swapped them out. The second fried beautifully, too, at 250F so if they are off, they are both off by the same amount, but I think it is more the stainless/copper construction. Nothing stuck to the pan and each latke was perfect. I cleaned up the pan to like new appearance (no scratches, I only use plastic utensils) and repacked it. One day, I hope to get my huge collection of MIB housewares, electric and non-electric to the Johnson and Wales museum.
