I'm flipping a '50s ranch and have an issue with the existing wiring. It still has all the original outlets - non polarized and obviously non grounded. By code I can install a GFI at the start of the circuit and have all the following outlets protected and use a 3 pin outlet. All well and good -- except- all the outlets in the rooms go to one central point -- the ceiling light. For lack of a better term I call this "spider" wiring, wondering if there is an actual term to describe this method/style of wiring.
I've been scratching my head for the easiest way to rectify this, nothing seems a like an easy fix. Only option I can come up with is identify the power wire going to the ceiling box, cut it, feed it to the nearest outlet and feed back from that point.
This house is on a slab, so all the wiring is in the attic, but I'm dealing with 12"+ of blown cellulous insulation. Anyone come across this issue and solve it? And just a disclaimer -- I've been wiring and rewiring houses for over 40 years, all my stuff passes inspection and I am totally comfortable working with all aspects of wiring.
