pezzy669
So I have had my Electrolux EFLS617STT for ~10 months now so figure it would be good to post some honest real world observations. Electrolux has updated the machine as of recently which appears to have added a pod slot in the detergent drawer and has updated some of the cycles, appears it was not much more than a mid-cycle refresh vs a full redesign.
Pros:
Capacity on this machine is a beast. One basket of laundry looks like absolutely nothing once you load it in the machine. Same with towels, what feels like a full load of towels (10-12 towels) is dwarfed by the capacity of this machine. For my 2 person household I can say I bought the equivalent of a minivan for a compact sedan job.
Cleaning - no matter what cycle you choose this washer cleans clothes quite well. 95% of the time I use the normal and casual cycles, whitest whites and heavy duty are reserved for towels, sheets and dog beds. My partner is hooked on the 15 minute quick wash which he says works just fine for turning around his work uniform.
Reversible door - I was backed into a corner due to the unique situation of my condo. I was set on getting a Samsung set but after measuring the openings in my condo it narrowed down my selection to Bosch or Electrolux which required 0" clearance on each side, all the others required .5" on each side. Additionally my laundry room incorrectly has the washer on the right, while reversible door was not on my mind when selecting a machine I am so thankful I have been able to flip the door on my Electrolux as I would have been up the creek with most other machines.
Design - The matching set I bought are fine looking machines.
Cons:
No easily accessible drain filter
Noise - I don't think Electrolux pendulum balancing system is as good as the active ball bearing system of other machines. It's been quite a few years since my last front loader (circa 2006 Frigidaire base special at Lowes) but quietness is not something Electrolux should tout. The drain and mixing pumps sound like they are about to walk off the job.
Energy use - yeah the needle on my electric bill does not move if I run normal cycles. If you select sanitize or PerfecfSteam your electric usage will skyrocket. My power company sends me daily usage updates of typically $1-2 per day, the times I wash dog beds on sanitize cycle I get a $4-5 usage email.
Overall it is a great machine and I am very happy with it. Despite the cons I wouldn't hesitate to buy another Electrolux.
Pros:
Cons:
