Electrolux Wascator WE 66MP At My Job (Vids)
fredriksam
Nov 2, 2005
743
Sweden
Well at my job we have two washing machines. One Whirlpool 11 kg machine and one old Electrolux Wascator WE 66 MP. This machine has a few problems. Its made by Völund in Denmark.
At first the machine didnt start (it hasnt been used for a while because of some problems). Eventually it did start and i made the machine go through the rinses and the end spin. It worked fine, expect from, The inlet valve is only letting out little water. The outlet valve (pump) is leaking some water. The PCB is not ok. The time left on the display is not the right one. The motor smells strange after the last spin.
I have made some videos of the machine. Here comes the first spin Test.
I thought the Thermostat was broken, but after a test with 95 Celsius that was not the case. The machine did heat up to 95. The door was very hot. When it emptied the hot water the water was very dirty so it was good i had it on that temperature.
Ok a little video of the rinse after it emptied the water. I had plans on filming the machine on the wash but had other things to attend to at the time sadly.
The machine go through the program as it should but took longer time than it should. Thats probably because the pump is leaking and the inlet valve is so slow. At the end of the last spin the machine started smelling strange again. Not excactly burned but a strange smell. dont know what to think about that.
Here is a video of the spin.
