Error code f0e4
pierreandreply4
Sep 7, 2007
2,739
St-Bruno de montarville (province of quebec) canad
Hello to all aw members i doubt any one has an answer for this, but i have a 3 year old Maytag mvw6230hw2 top load washer via the diagnostic mode. It shows in fault error F0E4 error code i have check online it eather say water in my home is to hot and washer is well install, do this mean that my washer is cold filled only i am no tech and this error code never appears on screen during a cycle i am also questioning myself if its not the washer fill hose thats causing the problem.
i am even questening myself if fill hose should not be switch right now the fill hose connected to washer are stainless steel braided hose
https://www.amazon.ca/-/fr/Solimeta...ix=maytag+washer+fill+hose,aps,91&sr=8-9&th=1
F0E4 code is Spin Limited by Water Temperature.  It presumably means the control board limited/reduced the spin speed to less-than-maximum on one or more occasions due to no cold rinse occuring after a warm or hot wash.
Fisher & Paykel has that protection function on their toploaders to reduce the final spin to no more than medium speed if a cold rinse didn't occur.
F&P states the reason is so "internal plastic components" on EcoSmart models don't distort during maximum spin speed if a hot wash hasn't been cooled by a cold rinse.  The "Hot Tub" flag on them restricts spin to no more than 700 RPM.  F&P maximum spin is 1,010 RPM or 1,110 RPM on later models, which is faster than your machine.
It's interesting that WP apparently incorporated the protection into some of the VMW machines.  I don't think they spin faster than 700 or 800 RPM.  Or maybe the protection flag is an artifact in the software/firmware ported-over from other models that do spin faster.
i have set spin speed to medium myself default speed on some cycle is rapid by default right now i am questing my self if washer itself is not a lemon since its a whirlpool made washer with the Maytag name on it this is my washer model mvw6230hw2 if it fails after 5 years and needed replacement i think i would go if i can convince my mom with the speed queen tc5 witch i tryed to convince my mom back in 2021 was the better choice
