Some of you might remember about a year and a half ago I was attempting to get my 1956 Hotpoint washer restored but ran into some major problems with the clutch. It turned out that the metal clutch locking groove had worn down to the point where the spin clutch was not being disengaged anymore during agitation and the tub would spin during the wash and rinse cycles. So I took the clutch spider to a machine shop and had them weld on a new piece of metal which worked for about 15 minutes until the new metal wore away the groove on the clutch jaw and once again I was out of luck. So at that point I gave up and threw the machine into storage hoping someday to find the right parts. Here is a link back to the original Hotpoint thread.
Thankfully last year Greg found another Hotpoint of the same design mechanically so I should be able to take two machines now and make one good one.
So yesterday I began work on combing the two machines, unfortunately the new washer’s agitator drive block is so worn that the agitator will only turn about 1/2 it’s normal stoke. Normally that wouldn’t be a big deal and I have a new drive block ready to install, but in order to remove the old drive block you remove the agitator shaft simply by loosening two set screws under the clutch housing from beneath the washer and pulling the shaft up through the top opening. Wouldn’t you know it but one set screw came out easy as pie, the other absolutely positively refuses to budge. So the only option is to take the entire washer apart from the bottom so I can pull the agitator shaft out from under the washer. Oh well here goes…
