user 3941
I need to pick some brains in here...
First off...how do you adjust the water level for these machines so that they fill higher? I'm finding that I use the Reset function quite a bit when washing blankets and towels...my machine is only the "Large" capacity so adding more water usually does the trick for larger loads, to overfill it so to speak. I've never adjusted the water level screw before....How high can the water level go too, without danger of overflowing?
Also, how many "snubbers" do they have? Mine is very squeaky on spin and I want to replace them (I think at least one is missing). They are fairly expensive so I want to make sure I order the correct amount...without having to pull it out of the closet lol.
Thanks!
Thanks!
