Surgery
So, let's back up a bit. When she first arrived, she was so very, very pretty cosmetically. But, as you know, sometimes the prettiest faces can hide the deepest issues.
The first clue that something might be going on was a stream of minerals down the side of the motor, and on the underside of the hoses. This is, I've found, never a good sign, and seldom is it the case that those drips and leaks just "heal themselves." Or, as my grandmother used to point out, if the thing ended up in the thrift store, there may well be a reason why.
Application of water confirmed an issue--a plethora of tiny leaks around the tub-to-pump seal.
The old seal was revised later to be wider, although the double-lip that does the sealing is the same between the original and new part. What happened here, though, seems to be common with machines that undergo low use in Arizona--the seal itself shrinks, slightly. Suddenly, the circumference is no longer adequate to get those two tracks of seals to lap the porcelain, and the rest is history.
I've run into this phenomenon on one other machine--a lovely PowerClean that couldn't hold water, but was otherwise perfect. The big, rubber-stopper-like tub-to-pump seal had shrunk, and no amount of dinking around would get it to seal again. The shrinkage was so bad that the pump and motor actually would spin in place. Again, replacing the gasket resolved the issue, so this time I jumped onto PartsDirect and ordered the replacement, for a shocking $4. Yay, parts!
You can also see in the photo where another issue happens with these machines--either rust blossoms up from the tub opening, or tiny, hard particles (like tidbits of broken glass that have been sent through the wash system billions of times, so that they become the D&M equivalent of sea glass) settle in the low spot between the tub seal and the porcelain, and work themselves in. Once they do--and the seal is distorted--you can't get it to seal again without applying silicone. And why do that when a fresh one is just $4 away?
I cleaned out the debris around the pump to make sure the surfaces were smooth, and installed the new seal. On these machines, D&M made a self-locating ring underneath that snaps into two halves, into which the screws anchor from the pump assembly above. This makes working on these units light years easier than the old porthole-sandwich units that had to be disassembled in layers to extricate the pump assembly. If you're handy, you can even pull the guts out through the top. However, they don't provide a quick-disconnect harness on the motor, so doing so would require disconnecting several wires to the motor. Boo. Instead, I shimmed up the pump with cardboard from underneath, and raised it into the air just enough to effect the tub seal replacement. All told, it took about 10 minutes to do.
