Well I did it. You guys inspired me and I got my first vintage washer. A 1 - 18. Thanks. It appears to be an older model because there is no cold wash setting. The model number is WCD3T. Got good news and bad news. First the good. It works! It fills, pulsates, drains and spins. All the controls work. The cabinet and control panel are in great shape. No scratches, dents or rust.
However, when I unloaded it off the truck I layed it on its back on the dolly. I heard a noise from inside the washer that sounded like a wire or spring breaking - "BOIIINNNGGG".
When I hooked it up and got it working I noticed that the lid switch was not working because the washer did not stop when the lid was raised for agitation or spin. Also, when off, the tub moves freely. When it filled and started pulsating, it pulsated at a good clip for a few seconds then slowed down. It's a 2 speed model and this happened on the normal speed. When I switched the control over to the slow speed there was a noticable difference between the 2 speeds, but the normal seemed too slow. It has stayed at that slower speed. When it did a drain/spin the pump worked great but the tub had a hard time coming up to speed- a lot of starting and stopping. The full spin does not seem very fast. There is also no tub braking action when it shuts off. The washer is LOUD and when it spins it has a scraping/grinding sound.
If anyone has any ideas on to what's going on I would appreciate any suggestions. I hope to have time this weekend to open it up and look under the hood.
