g3bill
My moms pressure cooker top handle was broken. I tried just super gluing it before with failure. This time took advice from sites and used a slow set epoxy, i used gel epoxy. After it dried I cut a brass tube to fit the screw hole and glued that in place as thats where it split. Got a very thin brass sheet to glue over the crack next to screw hole then a small brass machine screw to glue into a hole I drilled on opposite side of hole to hold the chipped piece in tight. Screw was cut about 1/8" shy then mixed bakelite drillings with gel to fill hole, looks okay and tried it without failure this time
Yes I could have just bought a handle for $5 but always wondered how to do this fix as theres other bakelite items I've had where a part was too old to find.
