I went and purchased this Asko washer the other day. The gentleman said it came with the house they purchased a year ago and that they had been using it during that time but recently they replaced this one with a new LG.
It was disconnected when I saw it and when I first spun the inner drum I was surprised to hear a ruff and noisy sound. I immediately thought it must be the bearings and was about ready to just try and make a graceful exit. However, the drum itself had no play and then after a few more back and forth rotations the noise stopped. Strange.
I got it home and removed the lower coin-trap cover and only found two coins inside; not bad. I did get the impression that someone may have been using too much detergent so I thought I'd start by doing a good flush. I used a water hose and ran about 3 or 4 tubs full of water through it. Out came what looked like many, many small pieces of saturated brown cardboard paper, but I'm not for certain what the material was.
At this point I thought I'd better just take off the bottom front cover to further check inside the base area. When I pulled off that cover I was shocked!
I found the bottom, especially towards the front, was just packed with what appears to be cat hair. It just spilled out but it didn’t look like any of the hair had affecting any of the operating parts down there – just covering and surrounding everything. It was also up on the top side in the control board, but to lesser extent.
It will be later next week before I can actually hook the machine up for a few test loads to see if it is still working properly as I was told. If so, you can bet it will get a boil wash or two either with bleach, vinegar or citric acid ?
It took me over 4 hours to clean this mess up! My only guess is that maybe someone placed a box or papers inside the washer, left the door open and that became the cat's home. Regardless, if I could have gotten hold of fluffy at his point I think she might have gotten a few minutes at 1,400 rpm's...
