Free 1970's appliances (Sacramento, CA)
That's a weird assortment of appliances.  An Electrri-Clean Frigideaire Deluxe double oven.  A reverse rack that probably replaced whatever was the original dishwasher.  (a photo showing the top rack being used for putting mugs & coffee cups in).  Tappan gas cooktop probably original.
Gotcha' Bob.
I have RR installed as the back up. Because psychologically I feel that just looking into the machine, I am so programmed to looking at the Wash Arm on the bottom I try to load as normal.
None of my Stock Pots fit on the bottom rack, so if I place them in the upper... They come out " Ehhhhh ". Reverse Racks to me are true "Dish Washers".
One Armed Wonders the same. Follow the Instructions for Racking... and Dishes and Glasses will come clean.
But RRs ? They are different. A lot of thought with a RR needs to be arranged with Spray Deflection in mind. My Flat Ware leaves a lot to be desired with that Basket in the Top Rack.
RR Maytag DW as A Pot and Utensil washer ?
Hi Ken, are we talking about the same DW, even with the top rack out you can not put a decent size stock pot in the lower rack let alone put much along the sides of the cutup lower rack, I can not think of a worse design for large pots, and trays etc for maybe a wash tower GE DW.
John L.
