Frigidaire Agi Tub Washer Laundry Center
Chetlaham
Mar 11, 2013
4,231
United States
Does anyone have videos of the complete cycle or pictures of the agi tub laundry center? Surprisingly I've never seen one in person and there isn't a whole lot on the internet about them.
"skinny mini"?
Do you mean the 1970-79 GM agitub?-initially i thought you meant the "immersion care"agitub machines,but those are "delux" era. :)
Not much out there.
I looked around and could not find much either-found one agitation video-looked like a fairly fast ~170* stroke.Have only seen two of these in person-one at the dump in 1983,another at a used shop in 1990,sold in about a day...
It is sad to think the machine you saw in 1983 is probably long gone and no longer in existence.
Here is the service manual I found. The mechanism is fascinating to say the least like nothing I've seen before. I wonder if this could've been done on a full sized machine. The fills are timed, also something which peaks my interest. I wonder if that could've been a hold over from the solid tub days of Frigidaire or if there is simply no risk of clothing damage if someone accidentally advanced the machine into dry agitate so a simpler control system could've been afforded.
Considering how few seem to have existed these might have either been trouble prone or just didn't clean well.
BTW the 120 volt electric model seems to have a relay that turned off the heater when the washer's motor ran.
The Skini Mini in the video has made its way around the club. I acquired it from Gary Ball and added the rare SM fabric softener attachment from another member, Don. I then passed it along to RevinKevin, where Red Carpet Drew filmed it at a wash in at Kevin's years ago. From Kevin it went to Thomas a couple years ago and as far as I know is still with him.
It was an interesting design from GM Frigidaire and had a bigger washtub than the WCI stacked version which used the same cabinet. You can easily tell the GM design by looking at the control panel, as the GM version has two washer control knobs and the WCI has three. GM had no water level control knob. It was a solid tub with a timed fill. It had an overflow rinse.
WCI, redesign from the GM version.  That's how to tell if a given specimen is GM or WCI.  WCI has a water level selector, GM does not ... as Rich details above in Reply 11.  GM version being timed-fill has no need for a pressure switch.
