Or - Don't break the glass and come crying to us!
Since it appears there are many more Control Tower Frigidaires out there than we first realized I think it helpful for new members to have safe instructions on removing and installing timer blocks on these machines.
After many trials I have seen where the sticking points are and if you are not careful you will end up breaking the timer glass--SOMETHING to be COMPLETELY AVOIDED!
SO here are the instructions for safe timer replacement:
WI-57 TIMER INSTRUCTIONS:
Change Bulbs from the front:
- take off knob
- loosen timer mount from back
- pull timer back
- unscrew two front screws holding plate glass
- lift front up to clear retracted timer rod
- pull front down to clear top hold tabs
REMOVE AND REPLACE TIMER BLOCK FROM MACHINE:
-remove knob
-loosen light socket screws
-remove load size rod
-using a hand on FRONT guide timer shaft through GLASS
- push down on bulbs and sockets TWICE Once for socket and once for bulb glass to clear timer box
- timer block is now free to pull out of timer box
-remove leads
REPLACE:
There are 4 catches where the timer mechanism can stick and cause the timer glass to break!
-* Leads go back on with wires UNDER bulb sockets- between bulb sockets and timer body!
1&2 Sticking Points
-Leave bulb sockets screwed on BUT LOOSE so they FLOAT! There are two catches on installing the bulbs, when you slide the timer in or out the socket will catch on the control box bossings and then next the bulb will catch on the same bossings. You have to be able to push the bulb/socket assembly up and down to take out or put in the timer mechanism. Other wise you’ll jump the mechanism into or out of the box and break the timer glass with the timer shaft!
3&4 Sticking points: Guide harness over these two points
Three: the wiring harness will catch on the corner going into the hollow support shaft of timer box- guide harness past this point with your other hand
FOUR: wiring harness will catch on the BOSSING LIP of Timer box at bottom
Install timer mounting bolts
Then tighten the bulb sockets!!
Install load selector rod
- take off knob
- pull timer back
-remove knob
-remove leads
REPLACE:
1&2 Sticking Points
