Frigidaire Custom Imperial Cooktop and Oven
nostaglic2k
Oct 25, 2020
0
Ontario
Hello,
I acquired a home in 2014 which had the original Frigidaire Custom Imperial Cook top and Double Oven combination. This unit has worked like a charm until recently when I began having issues with the cook top.
After some diagnosis it seems as though I am in need of one small (6") radiant tube element, item original part number 6590804. Also it seems as though over the years the two large 8" burners have been replaced by incorrect elements which, while compatible, are not the correct elements (incorrect current and voltage specs) items
7521366
6562161 - which I believe after some research corresponds to Frigidaire item code 6590808
I have searched online and it seems all parts are no longer being made or replacement parts available. I considered converting the cook top to use newer elements, or also to an induction range if possible, but would really like to keep the original look and operation if possible.
Any assistance with this would be highly appreciated!
Thanks in advance.
Al.
