mrcoppertone
Hi All,
I've had this coppertone Cycla-Matic for a while now without any issue whatsoever. I'm pretty sure the previous owner never even had to have it serviced.
This morning, I noticed the refrigerator section dripping a bit. I have a thermostat in there and it only measures about 41 degrees if I leave it closed and on max cool for a while. It will quickly go over 50 if I open the door and stay there a while. It was hovering around 33 before and I had the cooling set barely halfway up so something definitely happened. If I had it on the max setting before, it would probably have frozen everything in the fridge.
The freezer section is ice cold and no issues there. I am noticing that the cooling plate in the back of the refrigerator section seems not as "frosty" on the right side.
Wondering if anywhere here has any troubleshooting/advice? Really would like to avoid a repair person if at all possible. They either say they can't fix it or that I should get a new fridge. I'm sure you can all imagine my reaction to that
I will say, the freezer compartment was severely frosted before this happened. I melted and cleaned up all the frost in case that was somehow causing this.
