Frigidaire DW motors
re; chopper blade,
Most machines don't even have one anymore because of the noise they made in pump outs.
That Frgidaire looks simple, but also cheaply designed. At least it was able to be fixed.
Jerome,
it has one, as the photo of the stainless steel blade depicts.
Quality and GE? Of course, I paid $800 for my GE profile in 2011.
It has the Prihana TR blade. I barely hear it. In fact, my machine runs at about 50 db. I added a little insulation in the toe kick because I glued cabinet finish wood to it so it wouldn't rattle at all.
Induction motors are significantly better then brush motors. Yes a very poor induction motor might fail before a good brush motor, but in my experience GE has some of the best motors for any modern dishwasher. The redesigned motors from 2000 are still chugging along. Comparing a brush motor to a GE quiet power motor is imo a no brainier.
If Frigidaire is still using brush motor on their DW I do not think that looks good in terms of reliability.
Well you'll be crying in your Cheerios to hear that GE and Elux now source their little brush motors from Johnson Elrctric. A Chinese firm with an English name.
They're AC fed, but have a built in AC/DC converter and permanent magnets.
All make the same distinctive brush 'whine'.
Though they seem pretty powerful thus far.
True Chetaham;
A motor is as good as its bearings, rare earth induction magnets, or armature windings and carbon brushes.
On a copper wound motor, all it takes is one broken spot to cause failure.
GE's induction motors
Chet, you're 100% correct.
The very low end standard tub GE machines still use the now "old" (aprox. 1/8hp) induction "quiet" motor.
I believe they're now made in China and Vietnam.
Sadly....they used to be made in the USA and Germany back in the 'good old days.'
They're still a great motor though. Probably my favorite.
Rectified DC perm magnet motors are used in all kinds of machines these days----From --dishwashers-disposers,power tools,sewing machines,electric lawnmowers,the list goes on!!!Neodonyium magnets have improved these motors-making them more powerful in less space.The perm magnet is the feild-or stator-the armature or rotor is fed power with brushes as on a universal motor.Now "digital" SR motors are replacing perm mag ones in some applications.The SR motors are more expensive-they require a circuit board with the digital electronics to run the SR motor.
motors,
I do not know about Frigidaire, since I know of so many problems with them.
I'd never buy one.
Throw good money after bad, or do it right the first time.
As my dad used to say, buy a good machine, take care of it, and it takes care of you. Whirlpool, Kitchen Aid, Kenmore by Whirlpool, GE.
Unless you can afford a high end Asko, Miele or Bosch.
